Oil Pan Removal
Old 09-26-2004, 05:40 PM
CColtManM's Avatar
Oil Pan Removal
Do i need to lift the engine to remove the oil pan? Or will it hit the crank or oil pump inside?
Or does it unbolt and pull right off?
CColtManM is offline
Old 09-26-2004, 05:44 PM
dmoor88's Avatar
Re: Oil Pan Removal
yes continue to lift the engine half inch by half inch until the pan comes out.
dmoor88 is offline
Old 09-26-2004, 05:49 PM
CColtManM's Avatar
Re: Oil Pan Removal
But why do i have to lift it?
What does the oil pan have to clear? It looks like it comes right off.
Old 09-26-2004, 06:00 PM
ScrmngChckn95's Avatar
Re: Oil Pan Removal
with your automatic the oilpan comes right out.... its the m6's that have to slightly raise the engine to drop the pan.
ScrmngChckn95 is offline
Old 09-26-2004, 06:21 PM
CColtManM's Avatar
Re: Oil Pan Removal
Can someone confirm this?
Old 09-26-2004, 06:26 PM
Re: Oil Pan Removal
do a search, I found lots of info when I redid my oil pan gasket a little while ago
Old 09-26-2004, 06:28 PM
pearlpurple's Avatar
Re: Oil Pan Removal
TTT
I hope this is true as I would like to check on my oil pick up and also see what crap I have in the bottom of the oil pan.
pearlpurple is offline
Old 09-26-2004, 07:20 PM
12SCNDZ's Avatar
Re: Oil Pan Removal
You have to lift the engine 3" EVEN WITH AN AUTO. The reason is because you have to clear the crank. There's not enough room between the block and k-member to get it past the crank with the engine mounts still bolted.
Frank
12SCNDZ is offline
jer4251
09-21-2020 09:42 PM
HectorM52
07-30-2017 11:46 AM
DirtyDaveW
03-15-2015 07:01 PM
Queens94z28
12-20-2014 09:11 PM
Elcojoe
11-17-2014 10:27 PM
Quick Reply: Oil Pan Removal
