lt4 km or lt1 km
lt4 km or lt1 km
what is the difference in resistance reading between the lt1 and lt4 knock module. cant you use your lt1km then just solder a resistor in the line?? ive seen it done with tpi engines when they swap from maf to sd and was just curios because im gonna be buying a lt4km soon.
thanks
thanks
Re: lt4 km or lt1 km
This belongs on "LT1 Engine Tech".... but to answer your question..... the knock module is a chip with a fairly complex filter circuit on it, to filter out noise signatures/patterns/frequencies that are known NOT to represent engine knock. The chances of picking a resistor that would allow the LT1 module to assume the charcteristics of the LT4 circuit would appear to be unlikely.
What are you trying to accomplish? The knock module is a $25 item, that is prepackaged to fit into the socket in the PCM.
10-31-2016 11:09 AM
95chwagon
01-13-2015 09:19 PM
