LT1 rocker arms
Old 11-27-2012, 04:50 PM
77 Formula's Avatar
LT1 rocker arms
Are the LT1 rocker arms the same as on a regular 350
77 Formula is offline
Old 11-28-2012, 04:39 PM
Bersaglieri's Avatar
Re: LT1 rocker arms
Factory or aftermarket? Give us a few more details or better explanation.
Bersaglieri is offline
Old 11-28-2012, 05:26 PM
77 Formula's Avatar
Re: LT1 rocker arms
Mine are stock on my LT1 and I was wanting to put a set of stmped steel 1.6 roller rockers on it. THANKS FOR ANY HELP YOU CAN GIVE ME
Old 11-28-2012, 05:47 PM
Re: LT1 rocker arms
Can you yes. Should you...well that's debatable. You stock springs won't last long with the added lift, and the benefit from going to 1.6 from 1.5 is marginal if you are not going full roller. Lot's of threads out there on what springs you can run and recommended rockers.
Old 11-29-2012, 04:11 AM
kateean2's Avatar
Re: LT1 rocker arms
Great site. A lot of useful information here.
Last edited by Injuneer; 11-29-2012 at 05:29 AM. Reason: Malicious embedded links deleted
kateean2 is offline
Old 11-29-2012, 05:29 AM
Re: LT1 rocker arms
I guess that's important to a Chinese spammer, embedding malicious links in posts.
Bye.
Injuneer is online now
Old 12-04-2012, 11:54 AM
quicksilver97ta's Avatar
Re: LT1 rocker arms
Been a while since I visited this issue but be aware your stock rockers may be 'self-aligning' and the aftermarkets are not. They require pushrod guide plates and that requires hardend pushrods.
quicksilver97ta is offline
1775.Z28
01-11-2015 10:51 AM
BIGCOWL-IMP
12-19-2014 06:59 AM
Brandon Wittmer
12-07-2014 12:15 PM
squinn
08-04-2002 01:06 PM
newby
07-25-2002 03:22 PM
Quick Reply: LT1 rocker arms
