lt1 engine swap
Old 11-03-2014, 10:07 PM
nikko's Avatar
Question lt1 engine swap
Hi while on vacation I came upon a 1993 lt1 with a six speed auto and only 50,000 miles on it And already dressed up real pretty. Question on my 96 lt1 w/4 speed auto w/130,000 miles, would I need his pcm and should it bolt right into my 96 The engine is in the family so I will trust him cause it's sitting on a crate covered up trans is also hooked up
nikko is offline
Old 11-05-2014, 11:51 AM
nikko's Avatar
Re: lt1 engine swap
thanks for response was just trying to see if it was something I wanted to pursue
nikko is offline
Old 11-05-2014, 01:59 PM
lt1-xjs's Avatar
Re: lt1 engine swap
Use a stand alone engine harness and it would be a cake walk. I would use the '93 ECM.
lt1-xjs is offline
Old 11-05-2014, 02:42 PM
Re: lt1 engine swap
The main problem with using a 93 T56 in any application is that it has much different gear ratios in the lower gears (there are actually 2 different 93 gear sets), and has a lower torque rating.
4_3
Using the 93 ECM will require that you live with the batch fire injection (instead of full sequential), and speed-density (in lieu of mass air sensor).
Injuneer is offline
Old 11-05-2014, 06:44 PM
nikko's Avatar
Re: lt1 engine swap
Thank you all I think I'll stay the way I am
nikko is offline
Old 11-10-2014, 06:13 AM
Strick's Avatar
Re: lt1 engine swap
Maybe I missed something here, but why not just take the timing cover off your 96 and put it on your 93 engine then use the 96 opti and ECM? Just replace the cam with OBD II cam and that should do it. Some states might have a problem with an original OBD II car that is really a OBDI set up. So just keep it OBD II.
Strick is offline
rocketman051894
01-30-2015 03:23 PM
InfernalVortex
01-17-2015 09:35 AM
cmdeshon
01-04-2015 11:15 AM
Ricardo
11-29-2014 10:58 AM
07-04-2005 05:00 PM
Quick Reply: lt1 engine swap
