installed cc306 now brakes suck
Re: installed cc306 now brakes suck
If manifold vacuum is to low you can install a vacuum tank. It will solve the braking problems. Does it feel OK at high rpms but bad at low rpms? If so jut install a tank.
I can't even tell the differance after my install. like the previous post said.......Is it only at low rpm's or high and low? Make sure the rubber grommets on the booster and intake are in good shape. I would bet it's a leak somewhere. JMO
does that vacume hose that comes out of where the fuel lines are do anything? also i dont have the air pump any more, but i am pretty sure that doesnt do anything
i got the car back today, and the brakes are only bad when i am ideling, if the rpms are up they work as good as before.
off topic but it is my post
what RPM do those of u with the 306 idel at in gear and in park?
My brakes suck too. Similar cam to 306. Just low vacuum at idle. I pull barely 10 inches. Get a Jegs or Summit brand vacuum canister. They're inexpensive ($50 or so) and do wonders for braking ability.
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
