Headers what's the difference 94-95 / 96-97
what is the difference between headers for a 1994 & 1995 and for 1996 & 1997 LT1. I have a 1997 Trans Am and the only difference I can see is for the dual catalytic converters which I plan to get rid of so my question is will headers from a 94/95 fit my 97
Re: Headers what's the difference 94-95 / 96-97
I'm not so sure the A.I.R. or the EGR manifold hookups are any different?
This is what a '95Z has for hookups (Thanks to Shoebox for the pic):
My '96Z hookups are the same; so I assume the '95 and '96 are the same.
I believe the only difference is the dual cat on 96+. My buddy put a pair of 95 Mac mid lengths & Y on his '97 SS, and the only difference I know of, is he had to convert to one cat and use rear O2 sims.
The Driver's side flange is different between the two, but since you'll be converting to a single cat setup, you shouldn't have to wory about that.
Thomas.
Thomas.
I had 94-95 headers with emission hookups on my 96. The y-pipe had no cats. There was no problem. I had to have an S-pipe made to hook up to the factory exhaust pipe.
But they will fit.
But they will fit.
.......I believe the only difference is the dual cat on 96+. My buddy put a pair of 95 Mac mid lengths & Y on his '97 SS, and the only difference I know of, is he had to convert to one cat and use rear O2 sims.
Thomas.
Thomas.
I was thinking about getting these
http://cgi.ebay.com/ebaymotors/1994-...spagenameZWD1V
Originally Posted by Injuneer
No one said the EGR was different. The diameter of the AIR connections is different between the single-cat manifolds and the dual-cat manifolds.
Thomas.
Mike
Originally Posted by MikeTR
I read in numerous posts that the Pacesetters are a NIGHTMARE for plug acess! Like you have to take the header off to get to the plugs. Just my .02
Mike
Mike
carguyshu
01-22-2017 11:19 AM
