after jacking up motor, oil pressure guage?
Hi, every time I jack up my motor my oil pressure guage is maxed out and wont move at all, makes me scared to drive it. Does anyone know what I did? It happened both times I took out my oil pan, which is why I have to raise the motor a little.
I am about to go fix the burnt plug wire (*$#@(*$&) and get this thing down the track...
so any advice is appreciated.
Re: after jacking up motor, oil pressure guage?
Also check to see if you broke the sending unit.
I broke mine while putting in the rebuilt tranny.
Its close to the firewall and if the engine tilts back it will break the sending unit.
Ditto
this oil sending unit... you mean the thing I screwed back into the oil pan?
I am going to try and find a picture of what I'm looking for, that is the same thing I was told broke the last time, and I had some ****ty shop fix it... not really but they tried.
thanks again
thanks again
The thing in the pan has NOTHING TO DO WITH YOUR OIL PRESSURE READING AT ALL, PERIOD.
Now then, your oil pressure sensor/sending unit are on the back of your intake.
You can always count on Shoebox to have a good photo of practically everything.
http://shbox.com/1/oil_pressure_sensor.jpg
ok, I rewired that thing in that picture... or at least reconnected it to the right wire w/ a wire connector type deal.. does it have to be sodered together? we just used the wire connectors and clamped each side hard, and it doesnt seem to read right yet...
sorry for my newbieness, I thought that was what the sender unit was, but I thought we fixed it too...
Originally Posted by robvas
On the LS1 they point straight up.
Why are they made of plastic?
07-04-2005 05:00 PM
