95 misfire/no power
Old 09-08-2014, 08:10 PM
Eddie95z's Avatar
95 misfire/no power
Okay, replaced motor, new wires, plugs and opti, cleaned and tested injectors, replaced FPR , filter and fuel pump, have 44 psi... car idles okay, feels like it has a lite miss, but as soon as i put it in gear it starts missing rally bad, if i try to drive it, it acts like it's out of time, no power, valves rattling popping out exhaust... I'm about ready for the match and gasoline test......
Eddie95z is offline
Old 09-08-2014, 08:21 PM
Kevin Blown 95 TA's Avatar
Re: 95 misfire/no power
Start with the basics - connectors to all sensors, firing order, get it on the scanner if you have one and see what does/doesn't check in. A 95 is harder to screw up the opti, but it can be put on wrong - some here have done it. Valve adjustments all out of whack - vacuum leaks... Agree it sounds out of time related, but check the easy stuff first.
Kevin Blown 95 TA is offline
Old 09-08-2014, 09:01 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
See if it runs better if you unplug the MAF sensor.
GaryDoug is offline
Old 09-08-2014, 09:49 PM
Eddie95z's Avatar
i've had a few people say i need a 94 knock sensor for it i'm using the 95 sensor but my pcm is 94
Eddie95z is offline
Old 09-08-2014, 09:51 PM
I'll go for either plug wires mis-routed or opti not indexed correctly.
shoebox is offline
Old 09-08-2014, 10:49 PM
AdsoYo's Avatar
I had an issue with a brand new opti once where it wouldn't seat completely against the block. There was MAYBE 1-3 millimeters of space so I thought it was no big deal. It ran horribly and when I took the opti back off, I saw the rotor was grinding into the cap. Just another possibility.
Also I didn't see you mention coil or ICM in your replaced parts list. But I would check plug wire routing first then unplug the MAF (since it's easy).
AdsoYo is offline
Old 09-09-2014, 10:21 AM
93-95 all use the same knock sensor. Should have roughly 4,000 ohm resistance.
Does the fuel pressure hold up where it should be when you start driving the car?
Injuneer is offline
F'n1996Z28SS
08-23-2023 11:19 PM
Keenan
01-19-2023 12:24 PM
DarkKnight
Exhaust System
19
10-17-2016 10:28 AM
NewsBot
05-16-2015 03:40 PM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: 95 misfire/no power
