12499224 LS6 Yellow Springs
Will the 12499224 GM LS6 "yellow" springs work on a LT1 in place of the 918 beehive springs? They are substantially cheaper. It looks like you could use them with the Comp Cams LT1 beehive retainer, but I can't be sure.
Anyone have these on a LT1?
Sounds good, I'm running the CC305 with the LT4 1.6 roller rockers. Should have lift right around .544. SDPC lists the yellow springs as good for .588 lift but GM parts Direct lists the maximum lift as .550. I still think that I should be safe either way......
racecarz28
03-30-2015 09:55 PM
