How do I remove my A4 Shifter?
Old 03-28-2003, 01:00 PM
DarkzSS's Avatar
Is there any easy way to go about removing my A4 shifter. THere is little room to work with to work with the metal tab. Any tips. Thanks
DarkzSS is offline
Old 03-28-2003, 01:17 PM
2001NBMZ28's Avatar
Put the key in, turn to run. Put your foot on the brake and shift the lever into 1st.
2001NBMZ28 is offline
Old 03-28-2003, 01:20 PM
DarkzSS's Avatar
Do I pull the tab or push?
DarkzSS is offline
Old 03-28-2003, 07:06 PM
redz28kn3007's Avatar
Have the same question: how do you get this **** off ??? What metal tab are you talking about ???
redz28kn3007 is offline
Old 03-28-2003, 07:45 PM
SpecForceZ28's Avatar
There should be a staple behind the shifter.
Toward Dash (Staple is located on this side.)
Toward the back seats
To remove, just get a flathead screwdriver, and pry it off. Then all you do is pull the shifter off!
If you need pics with this, let me know.
SpecForceZ28 is offline
Old 03-28-2003, 10:34 PM
DarkzSS's Avatar
How do I remove the emergency brake handle? There is one little screw but it keeps turning.
DarkzSS is offline
R@mpage
04-20-2015 10:02 AM
04-16-2015 09:57 AM
BigWil
03-29-2015 12:24 PM
karpetcm
02-09-2015 09:21 PM
Quick Reply: How do I remove my A4 Shifter?
