"Drove 2000 SS through flash flood and now I'm paranoid" question
Old 03-04-2015, 07:28 PM
jasonduaine's Avatar
Question "Drove 2000 SS through flash flood and now I'm paranoid" question
Hey fellas (and gals),
I lost my '95 LT1 to hydrolocking recently (I didn't know what hydrolocking was then). I think it sucked up loads of water during a flash flood thanks to the K&N FIPK I installed.
Bought a 2000 SS Camaro after this, and, wouldn't you know, ran into another flash flood Sunday night. The car struggled to go through the water, which was about 4 inches high, but never shut off on me, like the LT1 did. I drove relatively slow, but water still flew up pretty high while making my way through. Checked under the hood when I parked, and there were some droplets scattered about, but the air filter (K&N) and everything else seemed dry.
There's been some squeaking from under the hood since then, and I'm suspecting it's one of the a/c pulleys (water messing up one of the pulleys makes sense, right?), but drives normally.
My main question is, should I go through the steps one goes through when they hydrolock, like checking spark plugs, changing oil, even if it didn't shut off? Or are there other precautions I should take?
Trying to make this Camaro last for the long haul, would hate to lose another one. Any help is appreciated.
-Paranoid
jasonduaine is offline
Old 03-04-2015, 08:04 PM
8cylinders>4's Avatar
Re: "Drove 2000 SS through flash flood and now I'm paranoid" question
The air filter is considerably more protected from water with the ls1 setup compared to a cold air lt1 setup.
Unless the air filter was soaking wet I wouldn't worry about it. The squeaking is no doubt from an idler or tensioner pulley in the accessory drive.
Water flew up pretty high huh? maybe take it easy through standing water? These cars are low slung bottom breathers, dont make the same mistake twice..
8cylinders>4 is offline
Old 03-04-2015, 08:12 PM
O.K., I'll check the pulleys tomorrow morning and take the time to change them out myself. Thanks for the reply! Yep, it sucks, totally wasn't expecting that amount of water out of no where. Next time I'm just going to pull over and wait. Not going to press my luck.
Old 03-07-2015, 09:44 AM
A squeaking pulley due to water intrusion should respond to a liberal spray of WD40. The "WD" stands for "water displacement".
Injuneer is online now
jayvar
02-02-2015 10:00 PM
Deadbolt24
01-19-2015 01:29 PM
Jazsun
12-29-2014 12:14 PM
Hurin
12-13-2014 07:38 PM
Quick Reply: "Drove 2000 SS through flash flood and now I'm paranoid" question
