Weird Electrical Issues
I'm having all of these issues. Im not sure if they are all related, but they all happened at the same time.
THE ISSUES:
_____________________________________
Both turns signals don't work (hazard's do).
Right door locks/windows do not work with the switches on the right side, but the locks work with the FOB and the left switches. However the right window does not work w/ the left switch for it. (hopefully this makes sense).
and i don't think this is related, but my key/keys haven't been working some of the time. You can get in the car and turn the key several times and it will turn on. I've tried both keys and i've measured them with the meter and they seem to read the correct resistance based on the information i've found online. Today it would not start at all and i tried for about ten minutes with no luck. My mom took me to work and i got home and sprayed some contact cleaner and it seemed to work, but it is very random when it works or dosen't. This issue started after all of the other 3 problems.
THE ISSUES:
Since we don't know the year of the car(or I didn't see it because of all thebeer)Did you put in an after market alarm system,or did one come with the car?Then maybe that could be the issue I dunno.Hope this helps,because any changes you or the previous owner made to the electrical system might cause this.My02.
eanhl2004
04-04-2015 12:01 PM
