loose door handle causes?
Old 06-20-2010, 06:54 PM
Joe Bellman's Avatar
The outside door handle on the drivers door is getting loose like something is worn. The door still opens but there is a lot more play (jiggle) in it than the passenger side. What is the normal cause of this? Cheap/easy to replace?
Thanks!!
Joe Bellman is offline
Old 06-24-2010, 01:12 PM
6772owner's Avatar
I am curious as to the answer for this as well, Im new to F-bodies and havent a clue how to fix this either. My speculation is there are bushings in the pivot assembly that wear out?? So new door handle is the fix??
6772owner is offline
Old 07-02-2010, 06:59 AM
Anybody?
Old 07-02-2010, 11:33 AM
moparman's Avatar
Take the inner door panel off. Look and see if the plastic clips that attach the handle to the rod are broken or loosening up.
moparman is offline
Old 07-02-2010, 01:50 PM
rgr, thanks!
Old 07-11-2010, 12:11 AM
Interceptor1's Avatar
Usually is because the return spring broke at the tip and is loose or fell off. That happened on a 3rd. gen. I had.
Interceptor1 is offline
2QUIK6
09-17-2016 02:31 PM
Henson071
09-18-2015 04:01 PM
cohopefull
09-08-2015 03:22 PM
cmsmith
08-09-2015 07:30 PM
CARiD
07-07-2015 08:19 AM
Quick Reply: loose door handle causes?
