idle problem?
idle problem?
any ideas on what the problem can be? My camaro runs strong while im giving it gas, but when its idling the rpms go up and down almost like its gonna die (never actually does tho) at night i can actually see the lights go bright to dim as the rpms go up and down. Occassionaly the car does die when i put it in reverse and dont give it gas. any ides? its a 96 z28 automatic trans
Re: idle problem?
The computer (PCM) uses the idle air control valve (IAC) to control the idle speed. Could be a problem with the valve, or you may have a vacuum leak that has caused the PCM to close the valve down, and it can no longer control the idle.
Re: idle problem?
My 93 Z does the same thing. No check engine light but I did hook it up to a scanner and everything seems to be operating smoothly. Mine really only does it after about 15 minutes of idling. I have never had it shut off either. maybe it has something to do with the JET chip which I have also. Z28pete may be on to something here. Im going to leave mine alone for right now as it doesn't bother me that much. Good luck with that though hope you figure it out.
___________________
93 Formula Mods: 383, LE2 Heads/Intake, 226/230 cam, 52MM TB, Magnaflow cat back, LT headers, cheap car part, CAI, SFC, Strut Brace, Adj LCA, Adj Panhard, Relocated Torque Arm, Progressive Rate Springs, Short Throw Shifter
___________________
Magenta_Hearts
03-05-2015 07:01 AM
slothgrant
08-22-2002 03:01 PM
