Brights won't work.
Old 02-20-2014, 07:56 AM
Armyjoe88's Avatar
Brights won't work.
So I replaced my turn signal switch in my 99 z28 and ever since my brights havent worked. It doesnt even click when I pull the switch. But the turn signals and everything else on the switch works.
Armyjoe88 is offline
Old 02-20-2014, 05:47 PM
parkers Z28's Avatar
Re: Brights won't work.
Was it a oem switch ??? have you checked the fuse / relay ?
parkers Z28 is offline
Old 02-20-2014, 06:53 PM
Armyjoe88's Avatar
It isn't a fuse or relay. Because when you pull the bright switch usually it clicks. Now it doesn't do anything. The switch I installed was an AC Delco switch from an auto parts store. Everything works but the brights.
Old 02-20-2014, 07:46 PM
figured that just.
Something must have went wrong in the installation or you have brand new switch that doesn't work
Just curious have you tried to use it in both directions ??
Old 02-22-2014, 03:57 PM
The actual dimmer switch is on the lower part of the column. You might want to check to see if the rod from the stalk is actually moving it far enough to operate it.
shoebox is offline
JJOHNROE
Parts Wanted
10-23-2015 02:03 PM
95craz28
11
09-12-2015 07:47 AM
Daluchman1974
09-11-2015 06:12 AM
z28cam1993
09-09-2015 04:08 AM
rideordie
09-07-2015 08:22 AM
Quick Reply: Brights won't work.
