anti theft problem
anti theft problem
OK, 2nd question of the day. I have a '95 Z28 that I bought a month ago. I previously owned an '01 V6. The '95 has an anti theft system that keeps activating if I just look at it cross-eyed. It goes off if I open and close the hood, or just sometimes for no reason. Worse, it goes off in the car wash. I don't take it through, and the car wash jockeys have to push it out at the end when they get in. Of course they have difficulty steering with no power on, so it's dangerous. When it activates, the lights and all dash lights flash and the car won't start. Activating the door unlock key disarms it. I have the shop manual but can find nothing on it, only the VATS passkey stuff, but this doesn't sound like that as once the door unlock key is pressed everything disarms.
Do you think this is aftermarket? I need to disable it. If aftermarket, how would they get the dash lights to flash - I thought that was PCM controlled?
Re: anti theft problem
shoebox,
Here's where I found out how to do it:
http://www.ehow.com/how_7788719_disa...vy-camaro.html
The LED is on the same panel as the OBDII connector.
charchri4
04-14-2015 06:40 PM
