A4 transmission tail shaft isn't tilting down after removing drivesha and cross brace
I'm stuck as to what to do to access bolts at the top of the bell housing. I've removed everything the service manual said to remove including flywheel bolts, (i think i got all of them) but the tranny's wont tilt back like it said it will do.
Re: A4 transmission tail shaft isn't tilting down after removing drivesha and cross b
First, make sure the oil pressure sensor is not up against the firewall. If it's clear, push up GENTLY on the harmonic damper.
Richardan15
05-30-2015 08:36 AM
