100 shoot of n20 + ?HP on dyno
So if i spray a 100 wet shot into a car already making 350 hp on a dyno will it go up too 450?
Does it matter what car it is on? if its for a 93 LT1 and rustang 2002 4.6
Re: 100 shoot of n20 + ?HP on dyno
You can interchange wet kits between cars... just the fuel jetting will change because different cars have different fuel system operating pressures. If its a dry kit, it probably can't be swapped from a 'stang to an LT1 because of the way you have to boost the fuel pressure in the LT1 to get the injectors to provide the extra fuel when you spray.
When they say its "a 100-shot".... that's just a rough number. The exact gains will be a function of how the kit is installed, line lengths, bottle type, etc. And as stated above, if you don't tune it correctly you may get even less.
Louey
Pacific
07-21-2015 10:06 PM
