Lots of Fuel issues Stock 95 LT1
#16
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: Lots of Fuel issues Stock 95 LT1
I unfortunately do not have a laptop, and my roommate probably wouldn't be ok with me downloading stuff on his laptop. Looking at the scanner and cable, how is that going to work? Does the 16 pin end of the cable go into the reader, then I adapt using the 2 wires, like shbox.com shows? My camaro doesn't have the obd1 connection.
Correction: I forgot that without the external supply, the tool will not scan; it just handles files already stored for the pc. So, you either need 12v at the DLC (94 no, 95 yes) or a cigar lighter power adapter like the one supplied with the CP9127 cable kit.
#18
Prominent Member
Just in case anyone is watching.... The CP9185 will work on a 95 without the CP9127 cable kit, because the 12v is already wired to the connector in a 95. I had forgotten about that.
#19
So, any updates on this? From what I see, you said I don't need any kind of external power output, and I'm ok to get the cp9185 scanner? Am I going to need that cp9127 adapter cable with it too? Huge thanks for looking into it
#20
Nickster 7
05-01-2015 09:04 PM
