The final rebuild.hoping for 650-700rwhp
Old 09-13-2013, 05:05 PM
95maroboi's Avatar
So i blew the piston rings on my 355 and decided it was time for a major rebuild.Im hoping for 650-700 rwhp with 12-15 psi.Is this realistic??This is also a California smog legal car.Heres the break down on the new motor
ENGINE
lt1 383
lunati crankshaft
lunati H beam rods
-31cc srp professional pistons
afr 195 eliminator heads hand ported (intake 300cfm/240 cfm exhuast)
Lt1 port matched intake manifold
custom blower cam 223/235 .610/.629 114
Power Adder
vortech v7 Ys trim
cog pulleys
Vortech aftercooler
Snow performance stage 2 methonal injection
I am still using the lt1 pcm.Any guess on what i should be making????
95maroboi is offline
Old 09-13-2013, 05:52 PM
Purple Poncho's Avatar
Re: The final rebuild.hoping for 650-700rwhp
Looks good. I'd go with a JE piston or similar 2618 forged piston. The SRP are good but seem best at 10 psi and under.
I think you are going to need way more then 12-15psi to make 700rw.
Purple Poncho is offline
Old 09-13-2013, 06:02 PM
95maroboi's Avatar
i called je to ask about that and they said these will handle 18 psi no problem as long as the tune is on point and wouldnt recommend switching over sense i already have these.Ive seen a couple lt1 make 700rwhp+ with 12-15 lbs with the same blower as mine so im hoping for the best but ill be happy with 650
Old 09-13-2013, 06:20 PM
I don't think you can just swap your stock stroke pistons over the longer 3.75 stroke. Might want to check on that.
Old 09-13-2013, 08:17 PM
95maroboi's Avatar
i have a new block going in the car .my pistons were .30 over in the 355 also.
Old 09-13-2013, 10:19 PM
97WS6SCharged's Avatar
I'd look into upgrading the aftercooler's heat exchanger and tank if you haven't already but you should have no problem making 650-700 rwhp with that head unit assuming everything else is up to the task.
97WS6SCharged is offline
Old 09-14-2013, 08:48 AM
DirtyDaveW's Avatar
Nice pieces on the bottom end. What compression ratio are you seeking? I would try to keep it in the 9.0 area. You'll have a stronger low rpm response that way. I have 8.5 and it's a bit soggy just off idle. I can run quite a bit of boost with the low compression but you have to stay in the throttle to get the benefit. On the freeways it's a monster, at stoplights, not so much.
That's quite the cam you have. Whom did you have to spec it? Looking forward to seeing your posts on how she runs.
DirtyDaveW is offline
Old 09-14-2013, 12:31 PM
95maroboi's Avatar
i should be at 9:2 compression.The cam was specd by lloyd elliot.I had to buy morel link bar lifters and 160lb seat and 480 lbs open springs just to handle this cam.Its suppose to have similar ramp speeds to a solid roller cam.My old motor had a 219/229 555. 555. 111.5 so im excited at the gains i should be getting over the previous cam that was in there
Old 10-28-2013, 08:45 PM
blown94's Avatar
Hey did you ever dyno or 1/4 mile your old setup? Curious cause it's similar to mine, but I never made it to the track before dropping a valve. Did you run an intercooler? I had meth
blown94 is offline
Old 11-18-2013, 01:51 PM
95maroboi's Avatar
i always ran into problems so no clean dyno.the most it made was 480rwhp 455 rwtq running out of fuel at 12lbs of boost.Thats through an automatic transmission
Old 12-12-2013, 09:15 PM
blown94's Avatar
That's pretty nice. Was that with the 100 shot? When I had the powerdyne and 100 shot I ran a best of 7.42 on about 7 psi. Then I swapped the vortech in and it was definitely quicker but never made it
back
blown94 is offline
Old 12-13-2013, 01:10 AM
Mr99SS's Avatar
im not into snow with plastic bull**** lines ...alkycontrol is the way to go .... hope you make your goal .... im 1200hp with a v6
Mr99SS is offline
Old 12-21-2013, 05:37 AM
BlackbirdWS6's Avatar
Your build is similar to mine so you should be able to hit your goal.
BlackbirdWS6 is offline
magman
04-15-2016 03:08 AM
PopoFormula
10-12-2015 04:19 PM
9t4lt4z28
10-02-2015 10:28 AM
Ks0209
10-01-2015 07:32 AM
kandied91z
09-30-2015 11:43 PM
Quick Reply: The final rebuild.hoping for 650-700rwhp
