Will a 95 Impala SS 4L60e fit in a 94 Z28?
Old 02-04-2005, 08:26 AM
My94RedZ28A4's Avatar
I seem to remember that 95's worked a little bit different than 94's. My 4l60e is in pretty bad shape right now, and I can get a rebuilt 95 impy ss 4L60e for pretty cheap.
will the splines, tailhousings, lengths, electrical connectors, blah blah blah work out? Is the valvebody any different? What about the convertor, is it the same stall speed?
I want to keep it as close to stock as possible as this is for my fiancee.
My94RedZ28A4 is offline
Old 02-04-2005, 08:34 AM
NOMAD's Avatar
Re: Will a 95 Impala SS 4L60e fit in a 94 Z28?
Should be exactly the same
-Shannon
NOMAD is offline
Old 02-04-2005, 08:36 AM
1SlowFormula's Avatar
yep, same thing as 4l60e in the f-bodies
1SlowFormula is offline
Old 02-04-2005, 08:43 AM
WS Sick's Avatar
Well the tail housing is different and if I remember right the output shaft is a different diameter. Someone please correct if wrong.
WS Sick is offline
Old 02-04-2005, 09:54 AM
You may have some issues in that the 95s use a PWM TCC solenoid and the 94s don't (at least on f-bodies). I would be reserved in saying it would be a direct swap.
shoebox is offline
Old 02-04-2005, 10:17 AM
Thanks Rob -- That's what I thought also. Do you think I could swap out the TCC solenoid from my 94 tranny?
Old 02-04-2005, 10:25 AM
CMSDave's Avatar
The shaft for gear selection is also a longer length.
The bell housing side tabs are also different, but I think it's in your favor.
Not sure on that last one, one case has big tabs, the other is cut down.
CMSDave is offline
Old 02-04-2005, 11:31 AM
sssalah's Avatar
I'm running a 96 z28 trany on my impy and the only part thats different is the tail housing. Both of them are PWM, you will know from the number of pins on the main harness connector.
sssalah is offline
Old 03-26-2015, 07:33 AM
Jirka Pospi's Avatar
im facing similar problem i have 6dbk 24833 4l60e from 96 impla ss will fit to my 95 Z28?
Jirka Pospi is offline
Old 03-26-2015, 09:04 AM
While both use pulse width modulated lockup, the actual control strategy and internal parts are different, at least between the F-Body versions of the 95 and 96 trans.
Interesting info:
LTXTECH Forums
Injuneer is offline
Old 04-03-2015, 10:12 AM
12SCNDZ's Avatar
Good article, Fred...LOL
Frank
12SCNDZ is offline
Old 04-03-2015, 10:16 AM
Hey Frank.... long time, no see. We need you here.
Injuneer is offline
HectorM52
07-30-2017 11:46 AM
01-05-2015 07:14 PM
Double aught
Parts Wanted
11-23-2014 06:11 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: Will a 95 Impala SS 4L60e fit in a 94 Z28?
