New Gears & LSD
#18
Re: New Gears & LSD
It will fit but won't have the reluctor ring required for your abs to work. The rings for three series gears are different than two series. I don't know if your two series one will work or not.
#19
Re: New Gears & LSD
FirstYrLS1Z Thanks for your help and Trac option is traction control option
Thanks rngilliland yeah the shop mentioned something about a tone ring i may have to buy for my brakes to work but it wont effect the abilty to drive my car ?
#20
Re: New Gears & LSD
So evidently a 'trac option car' means a 4 channel ABS & Traction Control. 4 channel ABS & TC started as an option in 1995. Your 1994 car/system is 3 channel ABS.
3 channel ABS cars have a tone/reluctor ring mounted on the carrier. 2 different rings,one for 2.73 & 3.08(2 series) and one for 3.23 & 3.42(3 series).
Your 94 would have had an Auburn posi carrier,the 2001 would have a Torsen posi carrier.
Using the 2001 parts will not allow the ABS system to function and the ABS dash light will stay lit,BUT the brakes will still have normal braking ability.
#23
Re: New Gears & LSD
so now where could i find one ? online maybe im gonna google this ring and see if i could find it thanks for all the help
#24
Re: New Gears & LSD
best of luck in your search. Sometimes you gotta buy a broken/worn out carrier just to get the ring off of it.
seen threads of broken rings in the attempt to it.
http://ls1tech.com/forums/gears-axle...oner-ring.html
#25
Re: New Gears & LSD
ok so do i need a abs tone ring for my gears to be set up correct i do understand if i dont have the ring my abs ring my abs wont work in the back correct me if im wrong
or do i need a tone ring to make the car even moveable
#28
Re: New Gears & LSD
Look at post #20..... IT HAS LABELED PHOTOS SHOWING THE RING AND WHERE IT IS LOCATED.
The ABS system adjusts the braking to the two front brakes and to the rear brakes as a pair. If any component in the system is defective (or not installed) the entire ABS system is deactivated and the "ABS INOP" light on the dash comes on.
ChrisFrez
03-22-2015 09:12 AM
