Differential check
Old 12-02-2013, 08:27 PM
1996LT1Z28's Avatar
Differential check
Is there an easy way to check if the rear on my 96 Z is a limited slip / open rear?
Thanks,
1996LT1Z28 is offline
Old 12-02-2013, 09:42 PM
Re: Differential check
Try a healthy burnout - 1 black stripe = open (or worn out limited slip); 2 black stripes = limited slip.
All V8's left the factory with a limited slip.
Injuneer is offline
Old 12-03-2013, 07:06 AM
1996LT1Z28's Avatar
Well then I guess my limited slip clutches are worn-out.
Is that somthing that can be done w/o going to the shop?
I'll just buy the clutches and do it myself if I doesn't take an act of congress to do.
Oh well, I'll get to that when I can.
Old 12-03-2013, 12:42 PM
I think the factory LSD is an Auburn cone type. I don't think you can rebuild those.
Injuneer is offline
Old 12-03-2013, 01:50 PM
FirstYrLS1Z's Avatar
^^^ true. Up to and including 1998 had Auburn cone-clutch. If it is past use-ability, it's best to replace ASAP, as the grooves on the cones are worn away and the cones have moved outward which in turn moves the cone's spiders away from the center shaft spiders, which in turn eliminates full tooth contact of the spider set. The spiders will break easier because of not full tooth contact.
FirstYrLS1Z is offline
Old 01-27-2014, 08:10 PM
1996LT1Z28's Avatar
It's late I know to respond, but where do I get a new Auburn differential that fits my 96 Z28?? Summit / Jegs????
Thanks!!!
Old 01-28-2014, 06:47 AM
getting a new differential(the proper one for your car as far as part number) will depend on what rearend gears you have. An automatic could have 2.73s(which would require a 2 series carrier) or 3.23s'(which would require a 3 series carrier). An M6 would have 3.42s' that would also require a 3series carrier. You need to find out before you can order in order to insure you order the correct one.
Old 01-28-2014, 08:31 AM
You are also not limited to an Auburn replacement. Eaton makes a very good disc clutch limited slip. Here's some info on upgrading the 10-bolt. Costs a lot for the little improvement you get, but may provide some helpful info. In these articles, they started out with an LS1 with a Torsen limited slip, but the principles are the same:
Strengthening The Rearend From An LS1 Firebird Formula - High Performance Pontiac Magazine
Fourth-Gen 10-Bolt, Part 2 - High Performance Pontiac Magazine
Injuneer is offline
Old 01-28-2014, 04:36 PM
^^^ agree, BUT the Eaton is only available in 3 series.
And don't forget the purchasing a used carrier. Most used for sale Auburns have some and/or quite a bit of service life left, and some are practically brand new with very few miles put on because the entire rear was upgraded to a larger rear.
teal98
15
09-16-2002 01:23 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
SilverWS6
13
08-14-2002 09:29 PM
newby
10
07-27-2002 11:39 AM
Quick Reply: Differential check
