are all 700r4's equal
Re: are all 700r4's equal
There are a lot of variations. I don't know enough about them to tell you what would work and what wouldn't. It should only take a day to rebuild it. Or, you can just use yours as a "core" and get a reman. Maybe $7-800 or a bit more (without a converter).
Rich
Rich
If yours is a true 1993 with a 5 pin plug on the side, then you will need to use your transmission as the one to build from, if not a 1988 & up will do as a start.
