what is so good about vortec heads?
Old 05-14-2009, 11:16 AM
ghost stripes's Avatar
this is the only place i figured this could be ask but i have a set of vortec heads every one tell me to put them on my ta that they will give me more horse power ...is this true whats so special about them?
ghost stripes is offline
Old 05-15-2009, 03:17 PM
angel71rs's Avatar
Vortec info motherload:
http://www.nastyz28.com/forum/showthread.php?t=56505
angel71rs is offline
Old 05-18-2009, 09:14 PM
n2ceptor's Avatar
And cheap to find......
GM Performance 12558060
n2ceptor is offline
Old 06-18-2009, 10:13 PM
budgetlt1's Avatar
sorry, they wont work on your motor.
budgetlt1 is offline
Old 07-30-2009, 08:18 PM
Stupified85's Avatar
if you throw a set of vortech style heads on that motor, make sure you have a vortech style intake manifold as the bolt pattern on them is diffrent.
also the vortech heads are arguable the best flowing set of stock gm cast heads ever made...now please keep in mind i say this is arguable, the stage II heads are imo the best of the best. more air=more power, just make sure thoes heads arent cracked cause i know they arent brand new
Stupified85 is offline
Old 10-13-2009, 11:28 AM
ssclone's Avatar
if you want to put them on your LT1, they will not work.
LT1 is a reverse flow motor, takes a lot of work to make a gen 1 sbc head to work on a gen II.
FWIW, the vortec head was styled after the cast iron B-body LT1 heads anyways.
if its going on a Gen I SB, 55-2000 (not including LT1) then you would need a vortec specifit intake, SA rockers, center bolt valve covers.
aaron
ssclone is offline
Old 12-24-2009, 07:45 AM
vetteoz's Avatar
Originally Posted by ssclone
need SA rockers,
If you run guide plates, you can use regular hardened pushrods and non SA rockers
vetteoz is offline
Old 12-24-2009, 10:00 AM
ssclone's Avatar
yes that is true too.
aaron
ssclone is offline
Old 12-26-2009, 02:19 PM
bigpapiken's Avatar
i need a carb for a 79
bigpapiken is offline
Old 12-28-2009, 07:44 PM
Dave1980's Avatar
people in hell want ice water....
Dave1980 is offline
Old 12-29-2009, 07:54 AM
ayers1967's Avatar
I have 4 sets now as they are dirt cheap . I have only one set of the 062 casting that in my opinion is the best ones to get. They have a very efficient combustion chamber and runner design .And as stated above , They will not work on your LT1. Gm got the design form the LT1 head . So even if it would work on your motor you wouldn't gain anything.
ayers1967 is offline
Old 12-30-2009, 09:09 AM
ayers1967's Avatar
[QUOTE=ayers1967;6216963]I have 4 sets now as they are dirt cheap . I have only one set of the 062 casting that in my opinion is the best ones to get. They have a very efficient combustion chamber and runner design .And as stated above , They will not work on your LT1. Gm got the design form the LT1 head minis the D port . So even if it would work on your motor you wouldn't gain anything.
Old 01-03-2010, 06:55 PM
EVERYONE????? Did you ask on the LT1 Based Engine Tech forum? I don't think you will get too many people telling you to put iron Vortec heads in place of your aluminum LT1 heads? As noted above, the Vortec was a copy of an LT1 head, for the conventionally cooled Gen 1 SBC engines. Great head, but still cast iron, heavy, and not as tolerant of the high compression ratio used on the F-Body LT1's.
You could buy a set of iron LT1 heads from a B-Body, and have the great flow numbers, without the problems of the mismatch on the cooling ports. Or, you could have any decent head porter port your LT1 aluminum heads to outflow not only the iron LT1 heads, but the even better flowing LT4 aluminum heads.
Injuneer is offline
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
Roadie
02-16-2015 10:34 AM
97TA-WS6-Con
02-01-2015 01:01 PM
InfernalVortex
01-17-2015 09:35 AM
Quick Reply: what is so good about vortec heads?
