Autocross and Road Racing Technique There is more to life than a straight line
ATE Super Blue Brake Fluid
Old 07-07-2005, 05:29 PM
dream '94 Z28's Avatar
I'm running a '98 Z in F-stock. Next year I plan to have some upgraded pads and do a few Performance Driving Events/Track Days. Mostly I'll be autocrossing 1-2 a month.
Should I run or do I need ATE Super Blue? The car nut in me sez 'yup.', but the bike nut want's it's time too. Is there an advantage to running it over off the shelf fluid? Thanks.
dream '94 Z28 is offline
Old 07-08-2005, 10:47 AM
Z28SORR's Avatar
Re: ATE Super Blue Brake Fluid
You probably don't need it for the higher boiling temp. But unlike standard brake fluid syn. doesn't absorb moisture. Standard brake fluid can absorb enough moisture to lower it's boiling temp. and of course cause corrosion.
Z28SORR is offline
Old 07-16-2005, 09:16 AM
MustangEater82's Avatar
I'd do it... I can't wait to start using it when I get back into working on my car again...
I have had lots of problems with off the shelf fluids and cooking them in my clutch and brakes...
I am generally a "save a buck" guy but I wouldn't skimp there but I do run my car in wetter/hotter enviroment then most.
MustangEater82 is offline
Old 07-18-2005, 10:31 PM
stereomandan's Avatar
I like it, but there is a version that isn't blue. The blue stuff stains plastic. Just get the ATE TYP 200 from www.raceshopper.com It's the same stuff without the blue dye.
Dan
stereomandan is offline
Old 07-19-2005, 09:59 AM
WOT
WOT's Avatar
Too bad all brake fluid is synthetic.
WOT is offline
Old 07-23-2005, 01:08 PM
nape's Avatar
Synthetic DOT 3 & 4 absorb moisture, which is why they have a wet and dry boiling point.
DOT 5 is (IIRC) a Silicone based fluid and does not absorb moisture.
nape is offline
05-01-2015 01:14 PM
CGM2010CAMARO
04-07-2015 07:44 PM
captcorvette
03-07-2015 12:37 PM
Red97LT1
9
12-17-2014 06:13 PM
bossco
11-29-2014 10:18 AM
Quick Reply: ATE Super Blue Brake Fluid
