How do I remove my A4 Shifter?
Old Mar 28, 2003 | 01:00 PM
DarkzSS's Avatar
Is there any easy way to go about removing my A4 shifter. THere is little room to work with to work with the metal tab. Any tips. Thanks
Old Mar 28, 2003 | 01:17 PM
2001NBMZ28's Avatar
Put the key in, turn to run. Put your foot on the brake and shift the lever into 1st.
Old Mar 28, 2003 | 01:20 PM
DarkzSS's Avatar
Do I pull the tab or push?
Old Mar 28, 2003 | 07:06 PM
redz28kn3007's Avatar
Have the same question: how do you get this **** off ??? What metal tab are you talking about ???
Old Mar 28, 2003 | 07:45 PM
SpecForceZ28's Avatar
There should be a staple behind the shifter.
Toward Dash (Staple is located on this side.)
Toward the back seats
To remove, just get a flathead screwdriver, and pry it off. Then all you do is pull the shifter off!
If you need pics with this, let me know.
Old Mar 28, 2003 | 10:34 PM
DarkzSS's Avatar
How do I remove the emergency brake handle? There is one little screw but it keeps turning.
R@mpage
Apr 20, 2015 10:02 AM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
karpetcm
Feb 9, 2015 09:21 PM
