How do I ge the stinkin' AC Compressor out!?
Old Mar 26, 2003 | 07:33 AM
jpolz's Avatar
Talking How do I ge the stinkin' AC Compressor out!?
My Hot Cam/Opti Swap project has tuned into a let's-clean-up-the-engine-bay-by-removing-everything-we-don't-need project. So I've removed all the plumbing from under hood related to the AC system.....all except for the compressor. I removed 3 bolts from the front the front and 2 from the back but I can't get it out. It wiggles quite a bit, but it feels like something is still attached. It looks like there may be some kind of strap around it or something??
Old Mar 26, 2003 | 07:39 AM
Just like an alternator, sometimes it can be wedged between the brackets. There is a bolt holding the rear bracket to the block. Remove that if you can get to it and see what that does.
Old Mar 26, 2003 | 06:43 PM
Janny's Avatar
Like shoe box says, find the bolt at the back of the comp that attaches to the block. You need to look up from just behind the right hand lower control arm. It's not too hard to get a socket on it with extension.
Old Mar 26, 2003 | 07:14 PM
kick Z tail out's Avatar
Wink
Wuss!
Just pull really hard.
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
