Fuel Pressure Dropping @ WOT...
Old Mar 25, 2003 | 02:41 PM
Camaro SS's Avatar
I was just doing a little tinkering this weekend and I have found something perplexing. With the vacuum line off of the AFPR, the fuel pressure immediately goes to 48lbs and stays there steady just like its supposed too. With the vacuum line still off, when I hit the throttle the pressure will drop 5-8 lbs and go right back to 48 at idle. Shouldn't the fuel pressure with the vacuum line off of the regulator stay pretty much right on? I do have a stock fuel pump still..... Any ideas??
Old Mar 25, 2003 | 03:03 PM
norcalstreet's Avatar
Hmmm, I would imagine that since fuel is being released into the cylinders through the fuel injectors that fuel pressure would go down a bit. Sorry I can't provide a more definite answer.
Old Mar 25, 2003 | 03:49 PM
Perhaps your pump is not capable of sustaining 48 psi. Check your filter lately?
Old Mar 25, 2003 | 04:35 PM
Camaro SS's Avatar
I just replaced the filter this weekend.........no change.
Old Mar 25, 2003 | 05:04 PM
I wouldn't worry about it. The engine wasn't designed to run with the vacuum hookup off. I would agree with Shoebox and say that your fuel pump probably can't sustain a 48 PSI fuel pressure.
Old Mar 25, 2003 | 05:07 PM
Derrick Redd's Avatar
Stock fuel pump? May be time to upgrade to the 255lph intank. I have the Walbro 255lph intank. I would definetly upgrade since you plan on running nitrous. JMO.
Old Mar 26, 2003 | 07:10 PM
Camaro SS's Avatar
Well it looks like it may be time to tackle the fuel pump. Racetronix........I guess????
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Burn_Out
Aug 18, 2002 08:49 AM
