Rear main seal leaking oil
Old Mar 24, 2003 | 09:13 PM
Ryan's Rod's Avatar
This has got to take the cake for the dumbest thing I've ever done. I forgot to torque down the harmonic balancer bolts to specs and the engine started making a clanking sound. Now I have an oil leak that appears to be comming from the rear main. Can I drop my 4L60E and redo it or do I have to pull the motor? Thanks guys.
Old Mar 25, 2003 | 11:01 AM
TW95Z's Avatar
If it's the rear main seal you can change that by dropping the transmission and removing the flex plate to get to the seal. What is making the clanking noise? That sound is pretty serious.
Old Mar 25, 2003 | 11:28 AM
Ryan's Rod's Avatar
the loose balancer was making the noise.
Old Mar 25, 2003 | 12:07 PM
93Z286Speed's Avatar
did mine when i first got the car... drop the tranny, u can get to it
Old Mar 25, 2003 | 01:04 PM
num's Avatar
num
with the motor out it takes maybe 10min to replace the rearmain. It's easiest to drop the oilpan and it's required to remove the flexplate/flywheel and tranny. While you're at it since you think it's the rear main seal that's leaking oil, change the oilpan gasket too. Get a nice 1piece rubber gasket and you'll never have a leak again, assuming everything else is ok with the motor. Let's hope that knock didn't damage something. Worth an inspection if you take the oil pan off.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Jessie4tin
Jan 7, 2015 08:53 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
