egr
Old Mar 24, 2003 | 03:20 PM
zuluman13's Avatar
egr
Can you pass inspection and is it leagel to remove the egr and what does it help how much more power.
Old Mar 24, 2003 | 03:31 PM
You can probably pass emissions. Only the most rigorous "rolling" dyno type test would include the load/rpm combinations that use the EGR system. However, if your engine tune is already marginal, there is always the risk you will fail due to excessive NOx.
It is illegal under Federal law to disable any emissions equipment. It may also be illegal under some State laws.... depends where you live.
It will not alter performance in any way. EGR is only used at low/moderate load. It reduces combustion chamber temps, reduces NOx emissions, and reduces the chances of detonation when "lugging" the engine at low rpm. It isn't used at WOT, so it doesn't affect performance.
JD30thZ28's Avatar
It doesn't increase power at all. Gains, cleaner engine compartment. In my case it was causing a low rpm stumble because the valve was sticking, removing it resolved that issue
Old Mar 24, 2003 | 03:33 PM
Bastardcat's Avatar
I highly doubt you'd pass inspection and it is not legal to remove it. I don't know exactly what kind of horsepower gains you could expect.
Old Mar 24, 2003 | 03:57 PM
PatriotTA's Avatar
It's only illegal if you get caught (or if you fail emissions).
Old Mar 24, 2003 | 04:08 PM
joeSS97's Avatar
One thing Fred didnt mention,is that it also increases mileage.You are better off with it working.
Old Mar 24, 2003 | 04:21 PM
1QUIKTA's Avatar
Here is a question along the same lines. I removed the egr tube and put the block off plates from Steve on them. I have MAC headers and the pipe wasn't butting up against the header and creating a leak. I left the EGR unit and did not use that block off plate. Is that going to create a problem? I know the guys that use LTs don't use the egr tube.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
