Stupid PCM question...
Old Mar 24, 2003 | 12:11 PM
Wolf Warrior's Avatar
I have a '97 A4 LT1, and I need to find a PCM and wiring harness...What PCM's will work? I've been told both '96 and '97 A4 PCM's will work and I've been told ONLY '97's will work...What is the truth?
Old Mar 24, 2003 | 01:14 PM
GREGG 97Z's Avatar
You can use either a 96 or 97 as far as I know, you definitely need to get one that was from an auto car, one from a manual would not work. I don't think there is any difference between the two years though, they are both OBDII.
Old Mar 24, 2003 | 03:21 PM
rskrause's Avatar
Moderator
Re: Stupid PCM question...
I believe that Ken Kelly at www.carputing.com sells reconditioned PCM's for ~$150 and can load a stock file for you. The serial numbers will not match though.
Rich Krause
Old Mar 24, 2003 | 03:29 PM
1996 or 1997 should work fine. You could also use the 1996 or 1997 harness with an OBD-I pcm if you wanted. It is harder to use a 1994-1995 harness with an OBD-II pcm, though.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
NewsBot
Sep 14, 2015 09:20 AM
