SHOEBOX gotta question for ya...
Old Mar 23, 2003 | 08:22 PM
ZPaul2Fresh8's Avatar
I was looking in your Tech page and wondered what the
"Adjust Steering Rack Bearing Preload" does ???? Tighten steering wheel play??? Thanks.
Old Mar 23, 2003 | 08:28 PM
Yeah, it tightens up the rack to steering pinion slack. If you are not experiencing any problems, I would not bother to mess with it.
Old Mar 23, 2003 | 08:39 PM
I should do that, my steering seems s little loose. Because of that I replaced both inner and outer tie rods but no improvement, so maybe I should try that.
Old Mar 23, 2003 | 08:44 PM
Try to isolate where the looseness is. Some people have found the intermediate steering shaft to loosen up and need to be replaced. That is the shaft that attaches between the end of the steering column and to the steering rack (has the joints on it).
Old Mar 23, 2003 | 09:03 PM
I just had that off of my car 2 hours ago when putting in the longtubes!
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
dansam
Jul 20, 2002 01:10 PM
