u-joint question
Old Mar 23, 2003 | 06:00 PM
danner's Avatar
u-joint question
Can someone help me out here i am not finding what i am looking for searching. I need to change my u-joints in my 97 z28. I switched to a ls1 DS. Are these the same as the LT1? I have read where folks have used NAPA 447X and some using 1350 series joints. Thanks in advance.
Old Mar 23, 2003 | 06:11 PM
jwilson2598's Avatar
They are the same exact u-joint.
Jeff
96 Formula WS6
Old Mar 23, 2003 | 07:00 PM
danner's Avatar
Thats good to know, thanks. Is there a u-joint out there that is considered extreme duty, one better than other, geasable, etc.
Old Mar 23, 2003 | 07:08 PM
You can just swap in the LS1 shaft. No u-joint change is needed.
Old Mar 23, 2003 | 08:14 PM
danner's Avatar
Shoebox thanks for the response, I did as you mentioned a year or so ago when i did the ls1 DS swap from my LT1 steel DS. I know have a little play and rattle when I manually manipulate the end of the DS. I just need to know if the ls1 u-joint is the same as the Lt1 when i go to purchase.
Old Mar 23, 2003 | 08:53 PM
Replacement u-joints that are greasable are actually not as strong as the non greasable ones, because they have to be hollowed out for the grease to travel within the joint body.
Choose which is more important. Strength or serviceability.
Old Mar 23, 2003 | 08:55 PM
danner's Avatar
Good info, So will (NAPA 447X and 1350 series joints) work?
Old Mar 23, 2003 | 09:13 PM
I will defer that to someone that has experience with them.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
ElkyRacer
Sep 19, 2002 02:33 PM
