Installing hooker LT's , Having problem's installing around Vortech T-trim
Old Mar 23, 2003 | 05:43 PM
Ben383's Avatar
I'm installing Hooker Lt's and I've done everything possible to install the driver side header with no luck . I've took off the valve cover release the stering linkage jack the motor up , but it keeps wanting to hit the supercharger . I was thinking of going from the bottom ,is this the way to go or would Ihave to remove the supercharger? Any help is appreciated . The supercharger is a vortech t-trim and where do you guy's usally jack the motor up from ?
Old Mar 23, 2003 | 06:08 PM
joeSS97's Avatar
I put mine in from the bottom.You shouldnt have to jack it up for that side.Jack it up from th oil pan with a block of wood to spread the load.The oil filter has to come off too.
Old Mar 23, 2003 | 06:11 PM
joeSS97's Avatar
I dont have a charger,but I will try to help all I can.
Old Mar 23, 2003 | 06:37 PM
insomniac 92z28's Avatar
If all else fails just drop the Cross Member. I switched to a 7qt. Canton pan on a 97 z28 and it is really easy to drop. Undo both motor mount bolts, undo 6 subframe bolts and it drops down 3-4 inchs. That should do it for your header. I have Hooker longtubes and a P1-SC.
Old Apr 14, 2003 | 11:27 PM
Highlander's Avatar
Remove the charger.. it will come in from underneath...
Noenav
Mar 1, 2019 07:38 AM
onefastgta
Mar 19, 2015 10:10 AM
ModdedNerd
Jan 1, 2015 10:56 AM
GigaMp3z
Feb 20, 2003 02:57 PM
LS1 RULZ
Aug 11, 2002 11:15 PM
