My horn doesnt work...
Old Mar 23, 2003 | 04:18 PM
meangreen94z's Avatar
OK, heres the deal, my horn doesnt work, it just clicks and the voltmeter goes down on the dash when i do it. Do you think this a problem, the kid before me pulled out the stock alarm because it kept going off so there is two wires just sticking out. How can I fix this? Thanks
Old Mar 23, 2003 | 04:21 PM
Laymaster's Avatar
that's weird. have you checked the obvious fuse to see if that's broken? if the fuse popped your cigarette lighter won't work either.
Perhaps those two bare wires under the hood just wire straight into the horn?
Old Mar 23, 2003 | 04:22 PM
Jawnnyt's Avatar
Re: My horn doesnt work...
You've got a ground somewhere. If you don't know much about electricity, find someone who does.
Old Mar 23, 2003 | 05:07 PM
I know somewhat about a electricity. I checked the fuse and it was fine. You can hear it short-out in or behidn the driver side firewall.
Do Z28s come with the alarm feature? It is on the drivers side in the engine bay. He ripped it out (literally) and now there is a red and a black wire just hanging there. What should I do?
Old Mar 23, 2003 | 05:41 PM
Eddie Z-28's Avatar
Just go and get it inspeced they'll do it for you.
Old Mar 23, 2003 | 06:15 PM
Inutero's Avatar
I had this problem when I first got my z28 too. I tried a bunch of stuff then finally I found a way to get it working. Open your door, get in, and if you look at your steering wheel, in the middle there's an area where the airbag is. there are 2 little indintations of horns, if you press on them slightly your horn should blow.
Old Mar 23, 2003 | 07:22 PM
smokindastangs's Avatar
I have the 2 wires hanging down too and my horn works fine.
sahlomonic
Parts Wanted
Sep 19, 2015 10:17 AM
War Engine
Aug 28, 2015 06:04 AM
fpete1992
Dec 11, 2014 03:51 PM
car_ramrod
Jul 17, 2003 11:24 PM
AL99Z28
Oct 19, 2002 10:13 AM
