What do you think about this Bellows????
Old Mar 22, 2003 | 09:48 PM
M3EATER's Avatar
Smooth Silicone Intake Bellows
It's more expensive than the rubber one ($54.95), but dresses up the engine compartment nicely...
Please take a look....What do you think?
PPC Silicone Intake Bellows, '98 -'02
Replace your stock accordion intake bellows with this PPC Silicone Intake Bellows. The PPC Silicone Intake Bellows provides a smother transition from the MAF to the throttle body, resulting in higher air flow & higher performance.
Similar to the PPC Smooth Intake Bellows, the Silicone Intake Bellows has two smaller humps as opposed to one larger hump. The Silicone Intake Bellows is thinner and is composed of reinforced silicone with stainless steel rings that can be removed if unwanted.
The PPC Silicone Intake Bellows will perform similarly to the Smooth Intake Bellows, while adding a nice detail touch under the hood.
Includes 3.5"/4" adapter ring and Marine Grade - 100% Stainless Steel hose clamps (band, clamp housing & worm screw are ALL Stainless Steel).
Thanks,
Gordon
www.provenperformanceconcepts.com
R@mpage
Apr 20, 2015 10:02 AM
C6LS3
Apr 15, 2015 09:50 AM
mark896
Sep 4, 2002 05:09 PM
Doubri
Aug 31, 2002 02:15 PM
speedy0009
Jul 18, 2002 02:21 PM
