Who has made a Vortech power pipe (solid intake tube) with PVC tubing???
Old Mar 21, 2003 | 03:15 AM
96 WS6's Avatar
I just need some tips on how to do this because it's going to be a project saturday =)
Old Mar 21, 2003 | 08:47 AM
Highlander's Avatar
I did...
What I did was this: I bought 2 90* elbows from a truck parts store and I soldered them together... I then used the rubber "connectors" and then I used a 90* 3.5" PVC elbow with a male end and a female end on the other side... Later I used a tube and drilled necessary holes... I used PVC glue (very important) and it has been working fine since!!!
Total cost??? ~80 since the 90* elbows where $28 each. I will probably change to metal later on, but so far so good.
Old Mar 21, 2003 | 11:41 AM
96 WS6's Avatar
Okay... I was thinking that the whole thing could be made from PCV... how do you seal it properly??? PCV glue, RTV, teflon tape? I need more info =)
It's basically just putting together the right combination of bends right?
Old Mar 24, 2003 | 10:19 PM
RCF925's Avatar
I made one with PVC and a couple of rubber boots at both ends. Gained 1 lb of boost and it was only about $15.00
Old Mar 26, 2003 | 08:21 PM
SiCk PuPpY's Avatar
Where did you get the rubber boots from? We are talking about replacing the "dryer" hose before the S/C, correct?
Old Mar 27, 2003 | 02:32 PM
Highlander's Avatar
On any speed and performance shop locally should have them.. very simple..
Old Mar 27, 2003 | 03:57 PM
Tech's Avatar
Not in St. Louis.
Air Flow Systems Inc. can help you. Search for them on google.
HectorM52
Jul 30, 2017 11:46 AM
onefastgta
Mar 19, 2015 10:10 AM
LT14LIFE
Feb 9, 2015 09:35 PM
alphaauto
Jan 23, 2015 07:42 AM
Joes96z
Dec 13, 2014 07:48 PM
