Dynatech LTs, Are Over-The-valvecover Wires needed???
Old Mar 20, 2003 | 02:10 PM
ZPaul2Fresh8's Avatar
Gonna install these in a week or so, I was wondering if I needed an Over-The-Valve-Cover wire set??? Thanks.
Old Mar 20, 2003 | 02:44 PM
joeSS97's Avatar
You would be smart to buy one.It is the right way to route the wires.Probably could use the stockers,but better safe than sorry.They look really sharp as well.
Old Mar 20, 2003 | 02:53 PM
turbo_Z's Avatar
they will save you from burning wires and posting on here how you have a mysterious low RPM stumble and high RPM miss and as said above... they look cool! ill just say either you buy them now or you buy them later... there might even be a group purchase still going on from thunder racing so check that out.
Old Mar 20, 2003 | 03:03 PM
EviLBoX's Avatar
They aren't absolutely necessary, but I'd recommend replacing your wires and routing them over the valve covers. If you do choose to keep the stock wires, watch out for the #6 plug boot and wire, it will touch the header if your not careful. #6 is the wire I burned right after my headers were installed, I then went over the valve covers.
Old Mar 20, 2003 | 03:26 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
I have them, lost of zipties will save you till you scrape up $100
they saved me
Old Mar 20, 2003 | 06:07 PM
I don't have stock wires, I now have MSD 8.5mm wires. I'm guessing since they are thcker they would be harder to tuck away from the headers, but I have PLENTY of zip ties!
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Don 97 SS
Jul 11, 2005 08:50 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
