Fuel line connections
Old Mar 19, 2003 | 02:44 PM
cd520's Avatar
What are the type of connectors that attach to the in/return stubs? Can you purchase them anywhere? Thanks.
Old Mar 19, 2003 | 02:57 PM
jonaddis84's Avatar
You talking on the fuel rail im guessing? Just to clarify for people that might know the answer. If you are I dont think so, they dont seem like connections you can put on yourself, but I might be wrong.
Old Mar 19, 2003 | 03:02 PM
cd520's Avatar
Yes to the rail.
Old Mar 19, 2003 | 03:05 PM
jonaddis84's Avatar
Explain why you need them. Did they get ruined, are they not there for some reason, ie. a swap?
Old Mar 19, 2003 | 04:00 PM
cd520's Avatar
Swapped a 96 LT1/4L60E into a 90 Camaro.
Old Mar 19, 2003 | 04:19 PM
jonaddis84's Avatar
Ahhh...What you might want to do is go to the junkyard and try to find an LT1 and just cut off the lines and either try to splice them together with the existing, or maybe reuse the fittings. But I doubt if you go to a GM dealer that they will have just the fittings. Try autozone though.
Old Mar 19, 2003 | 04:41 PM
The dealer does not sell the fittings separately from the pipe (at least on our cars). You might be able to find something aftermarket.
Old Mar 19, 2003 | 05:57 PM
cd520's Avatar
Ughh...I was afraid of that. Why cant anything ever be easy hehe?
bad96firechikin's Avatar
I'm in the same boat. I f-ed up the clips in mine, and can't seem to find anything aftermarket to replace them. You can get the entire part from GM (feed, return, and EVAP) from GMPartsDirect.com for about $45 plus about $45 oversize shipping.
DirtyDaveW
Dec 1, 2016 05:37 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
