Cc305 Vs. Hotcam
Old Mar 18, 2003 | 08:58 PM
stonecoldz's Avatar
Arrow Cc305 Vs. Hotcam
hey guys i've heard the cc305 makes more hp than the lt4 hotcam, if so how much more. Also, what roller rockers do u recommend for the cc305 and will it pass emissions in chicago? does com cams have a kit for their cams? if not what do i need? i will be taking my heads to phil for full port. thanks
Old Mar 18, 2003 | 09:16 PM
neil350's Avatar
Hey,
Do a search and you will find a lot of posts about this subject.
Old Mar 18, 2003 | 09:29 PM
chesee48's Avatar
Originally posted by neil350
Hey,
Dude tell me about it. Its kinda getting overdone. Put some effort into it, your find TONS of the SAME EXACT topic posts.
If you cant find your answers there, then post.
Old Mar 18, 2003 | 10:02 PM
neil350's Avatar
In the end you feel bad for the new guy, because I'm sure to them it seems like no wants to help them. Once they do find that magic search button, its amazing at how much information is in this board. You could spend days reading about all the stuff.
Old Mar 18, 2003 | 10:19 PM
Kain's Avatar
They both have about the same duration, I'm not sure what the lobes look like, so they should rev to about the same rpm.
LT4 has a 112 lobe sep compared to the 305's 114. So it'll make a bit more torque.
The 305 has more lift, it would have 540/540 with 1.6'rrs while the LT4 has 525/525 with 1.6's.
If your looking for a cam like this, just get a custom one ground from Comp Cams, it costs the same as a normal cam of theirs, $240+S&H.
Get a 220/230, 112 lobe, 520/530 lift, then with 1.6'rrs the lift will jump to 550/560.
On my next engine, I'll go with a CC305 like cam.
Old Mar 18, 2003 | 10:22 PM
Smokn '94 Z's Avatar
Lightbulb Re: Cc305 Vs. Hotcam
They are waaaaaay to similar to compare. I flipped a coin & by my times I am very very happy...
Don't mind everyone trying to pound the search feature down your throat..... Just get used to using it
MDZ28
11
Sep 24, 2015 09:15 AM
NewsBot
Jul 3, 2015 02:10 PM
Russ95Z28
Apr 23, 2015 01:55 PM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
