What year cable (laptop to pcm) do i need?
Old Mar 18, 2003 | 11:36 AM
twells's Avatar
Question What year cable (laptop to pcm) do i need?
i was under the impression that all odbI cars used an odbI cable. someone told me that even though my car is odbI since i have a 95, i must use a odbII cable? is this true?? thanks guys
thomas
Old Mar 18, 2003 | 11:43 AM
Hoostie's Avatar
You need the ob2 cable.
Old Mar 18, 2003 | 11:44 AM
twells's Avatar
awwww f, that's what i thought
Old Mar 18, 2003 | 03:23 PM
Dr.Mudge's Avatar
You can use an OBD I cable, you just cant use the OBD I adapter plug. My cable does not have the plug at all, it costs an extra $20 or so just for the plug, I was fine with just 2 wires. I got my cable from Steve Ruse with no adapter on it, just the 2 leads.
Old Mar 18, 2003 | 03:51 PM
twells's Avatar
how much less or more would your idea cost dr. mudge?? what are the advantages/disadvantages for each different option on the cables?
thomas
Old Mar 18, 2003 | 04:37 PM
Dr.Mudge's Avatar
Last I checked a fully assembled OBD I cable was $65, an OBD I connector used to cost somewhere around $25-$35, I dont know about an OBD II connector but I expect the same price approximately. You can either hard wire the cable in, or just remove the pins when done programming/logging, or I just have mine routed above the cig lighter box out of the way and let the rest sit on the passenger side of the floor when not in use.
So figure on it adding $25-$35 if you want the actual plug, but check the sites to see costs.
www.wotelectronics.com
Old Oct 19, 2006 | 01:40 PM
bubba24's Avatar
Re: What year cable (laptop to pcm) do i need?
I ordered from wotelectronics some steve russ guy , yah i ordered that sept 26 well over 3 weeks it still hasnt showed up. So akmcables is ur best bet.
DirtyDaveW
Dec 1, 2016 05:37 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 25, 2015 02:41 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
Jul 4, 2005 05:00 PM
