Installing Headers - Checklist...
Old Mar 18, 2003 | 12:37 AM
Laymaster's Avatar
Alright I just won a set of MAC Headers on Ebay...I'm going to need:
  • Taylor OVC Wires
  • Stage 8 Locking Header Bolts
  • Headers (obviously)
Am I forgetting to order anything?
Old Mar 18, 2003 | 12:46 AM
JKDZ28's Avatar
Pick up a set of gaskets and some high-temp RTV Gasket Maker
Might wanna pickup some bandaids cause your gonna need em
Old Mar 18, 2003 | 01:31 AM
GeneralZ's Avatar
I too just won an ebay auction for mac headers...is there anything included with them? I figured they'd come with the bolts and gaskets.
Old Mar 18, 2003 | 01:34 AM
Laymaster's Avatar
I'm picking mine up used from someone else, so I don't know what comes in your package. I would contact the seller if I were you.
Old Mar 18, 2003 | 04:54 AM
texasTA's Avatar
To install your headers, which I am assuming are shorties (possibly mids?), you will need
headers
header bolts
gaskets
RTV high temp gasket maker
And that should be it. Since they are not longtubes, you will NOT be able to do the over the valve cover set of wires. That is only possibly on the longtubes. The shorties you bought should have EGR and AIR hookups, therefore you will not need your computer flashed. And I believe your stock ypipe will bolt up to your shorties. You can change your plugs and wires if you want, that depends on mileage/need.
Good luck, and don't forget the case of ice cold ones and a HUGE box of bandaids
Old Mar 18, 2003 | 07:48 AM
Laymaster's Avatar
headers
header bolts
gaskets
My friend has MAC headers and he has over the valve cover wires...
Old Mar 18, 2003 | 08:05 AM
EviLBoX's Avatar
Not true, you can route wires OVC with shorty headers. You just can't do them with the stock manifolds. I'd also suggest not using any high temp RTV around the gaskets at the head/header, it shouldn't be necessary.
Old Mar 18, 2003 | 08:07 AM
DR.ZED's Avatar
Agreed with the RTV, you should be fine with the Felpro gaskets dry.
Second, the separate cylinder 7 piece that goes into the other three collectors WILL need RTV around the clamp. Use O2 sensor safe RTV for this.
Old Mar 18, 2003 | 11:53 PM
texasTA's Avatar
Well, you learn something new everyday. I was unaware that you could run OVC with shorties.
Also, I meant to use the RTV with the EGR plate that blocks off the back of the manifold.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
