HOT Cam Kit came today, what else should I do while I'm in there?
Old Mar 17, 2003 | 01:43 PM
jpolz's Avatar
Exclamation HOT Cam Kit came today, what else should I do while I'm in there?
My HOT Cam Kit came in today, I'm waiting on the rest the parts to show up within the next week or 2. I'm doing the 95+ Opti Swap, so I ordered everything needed for that, along with a new stock Water Pump. While I've got everything taken apart, is there anything else I can replace/upgrade while installing the cam. 2 things that came to mind were valve seals and oil pan gasket. What do you guys who have swapped the cam out done?
Old Mar 17, 2003 | 02:05 PM
GREGG 97Z's Avatar
Valve seals are a good item, but I wouldn't try to replace the whole oil pan gasket, it looked a little tough to swap to me. I reused the main pan gasket and I avoided tearing the front rubber seal as well and reused that, it was in good shape. It's a little tricky getting the timing cover back on without ripping the rubber gasket, just don't rush it is all I can say. I got the gasket kit from Thunder and replaced every other gasket though.
Finished mine up a few weeks ago, and no leaks at all I'm happy to say, and definite sotp feel from the cam
Old Mar 17, 2003 | 02:27 PM
ponyackn's Avatar
I would replace or upgrade my timing chain. Some also change out their waterpump. If you have the money, get your heads p&p'ed.
Old Mar 17, 2003 | 05:09 PM
1995redZ28's Avatar
hey jpolz i was just wondering what you had ordered in order to do the 95+ opti swap?? im looking at buying all the parts soon for the hotcam, and ive got a 94Z. just wondering how much you paid for everything to do the swap?? where did you order from? thanks in advance!!
Old Mar 17, 2003 | 05:20 PM
AxeGrinder30thZ's Avatar
Quick question...how much does a new cam affect your gas mileage?
Old Mar 18, 2003 | 07:15 AM
jpolz's Avatar
This website gives you all the part #'s necessary for the swap. As far as where I bought everything: I got the Opti from Jason Cromer ($195) and the rest I got from GMPartsDirect.com.
Old Mar 18, 2003 | 07:39 AM
oldBones's Avatar
I'm getting about 18 mpg with the hot cam and mods in sig.
Old Mar 18, 2003 | 09:03 AM
Smokn '94 Z's Avatar
Lightbulb
Inspect your pushrods to make sure that they are not bent. You should be fine cause yours are hardend but one of mine was a tad bent so I put in some comp hardend ones. Also inspect your lifters. I am still running my stockers but when I do my heads I will get new ones. You might want to upgrade the springs. Eventhough the kits springs should suffice, I think I might be expieriencing a bit of valve float with mine. Something to consider. Definately valve seals. Remove AIR pump. Really cleans up the engine bay. I painted my Timing Cover, Valve covers, TB & Intake. Car looks great. Good time to do it with the car apart.
Old Mar 18, 2003 | 12:47 PM
Z28SORR's Avatar
I second the head porting, no better time. If you have the money you could do over size valves also.
Old Mar 18, 2003 | 01:13 PM
shocktrp's Avatar
LT4 extreme duty timing chain set #12370835.
Old Mar 18, 2003 | 02:47 PM
num's Avatar
num
gmpartsdirect.com
has the LT4 extreme duty timing chain set:
OUR PRICE: $202.14
good price.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
StngStlkr
Sep 6, 2002 05:47 PM
Burn_Out
Aug 18, 2002 08:49 AM
