what does P0135 mean (autotap)
Old Mar 16, 2003 | 09:59 PM
stik6shift00's Avatar
I had my car autotapped a couple days ago (thanks stik98) and the only code i had was P0135...what does this mean..is it the o2's ??
Old Mar 16, 2003 | 10:20 PM
stik6shift98's Avatar
i think its an 02....
btw did u go see what it meant...autotap.com
Old Mar 17, 2003 | 07:47 AM
rncotton's Avatar
http://www.actron.com/code_lookup/index.php
P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
Old Mar 17, 2003 | 08:34 AM
and that means?????????????
Old Mar 17, 2003 | 11:36 AM
Mikael's Avatar
Check the wiring, make sure your getting a good feed.
Old Mar 17, 2003 | 12:27 PM
Blkknight's Avatar
Its means either your wires are fugged up on the front O2 on the drivers side or the O2 itself is bad. You may start getting some odd performance out of your car soon if you dont fix it.
Old Mar 17, 2003 | 01:06 PM
blkss01's Avatar
Will a code like this throw a CE light?
Also, If the light isn't on could there still be codes stored in the computer that haven't tripped the light?
Old Mar 17, 2003 | 01:14 PM
thanks alot.....i hope thats why my dyno is alittle low...and should this cost like $100 or so to fix? My car dies starting up sometimes..so i think this is the problem
Old Mar 17, 2003 | 01:31 PM
Blkknight's Avatar
Even if the SES light goes out the code is still stored.
Old Mar 17, 2003 | 01:34 PM
Blkknight's Avatar
If that. If you do the work yourself, and theres no reason not to, it will cost at the most $100 depending on if its the wires or the O2 itself. If you shop around you can find O2's for cheaper than $100. The wires will cost about $20 or so.
Old Mar 17, 2003 | 03:26 PM
he has already seen performance go down....thanks
i knew it was an 02 but i just didnt know which one
thanks
Ricardo
Nov 29, 2014 10:58 AM
LWillmann
Jun 4, 2003 11:53 PM
LWillmann
Jun 3, 2003 12:21 PM
dkeers
N2O Tech
10
Feb 9, 2003 06:43 PM
tbyrne
Jul 2, 2002 05:37 PM
