fan problems
Old Mar 16, 2003 | 09:45 PM
JonCaudill's Avatar
Unhappy fan problems
Ok here's the situation: When I unplug the AIR pump fuse the fans run full blast like they should. If I turn on the A/C they come on low. I just changed the water pump temp sensor today. The new sensor is showing good ohm readings and the plug shows right at 5 VDC. Unfortunately, my fans will not operate during normal conditions. I've let the engine idle up to about the 3rd line on my temp guage before I pussed out and turned on the A/C. Does anyone have other ideas to check out?? I suspected the engine block temp sensor to be faulty at first but the water pump sensor is showing ohm readings consistent with the temp gauge. Thanks for any help you guys can give me.
Old Mar 16, 2003 | 10:21 PM
The only way to tell what the pcm is actually seeing is to use a scan tool to monitor the temp and also the fan ON command. The pcm, itself, could be a suspect.
Old Mar 16, 2003 | 10:53 PM
JonCaudill's Avatar
ouch that sounds painful (cost of pcm fix)
Old Mar 16, 2003 | 11:08 PM
That is why the scan tool is needed to rule things out.
The cost of a pcm would not be too bad (used).
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
MattFick
Feb 15, 2015 10:16 PM
slothgrant
Aug 22, 2002 03:01 PM
