What bolts should i do next?
Old Mar 16, 2003 | 09:11 PM
AdamRmr's Avatar
Lightbulb What bolt ons should i do next?
What Bolt ons can i do to my motor for some more power?
What i have done.
EXHAUST
BBKHeaders
Y-pipe with no cats
02 sims
SLP cat-back system
MOTOR
BBK pullys
160 Thermostat
Taylor Pro Wires
NGK SPark plugs
Tb Bypass
MAF
K&N filter
Old Mar 16, 2003 | 09:14 PM
Larnach's Avatar
Get some new lug nuts man!
I'd do some suspension mods, road racer or drag racer?
Old Mar 16, 2003 | 09:22 PM
stik6shift98's Avatar
definetly need some nx
Old Mar 16, 2003 | 09:27 PM
BPS's Avatar
BPS
suspension mods
BTW the motor mod sure can cover a lot of ground!
Do you have aftermarket cam and heads?
Old Mar 16, 2003 | 09:39 PM
AdamRmr's Avatar
my suspension mods,and brake mods are all done trying to work on the motor.
Old Mar 16, 2003 | 09:41 PM
adrenaline24's Avatar
Can't go wrong with having your heads worked and throwing in a cam while your at it.
Old Mar 16, 2003 | 09:47 PM
95m6's Avatar
I second the nitrous!
or a supercharger if you have the extra $ laying around.
What about Drag Radials? didn't see those listed anywhere...
Also what about a
airfoil
k/n drop-in filter for ram-air box
1.6 Rocker Rollers (some see as a bolt-on others don't)
Those are about all I can think of right now..
Later
Old Mar 17, 2003 | 12:07 AM
smokindastangs's Avatar
58mm Tb + the cam and heads...then you are well on your way tooo....getting a speeding ticket
Old Mar 17, 2003 | 12:12 AM
Dupont24's Avatar
What about gears and a torque converter? I love the look when I jump out 3 car lengths at the light!
Old Mar 17, 2003 | 12:17 AM
good point, gears slipped my mind.
Old Mar 17, 2003 | 12:20 AM
Dupont24's Avatar
Hey smokin what kind of times are you running in the 1/8th?
Old Mar 17, 2003 | 12:26 AM
If only i knew....I haven't taken it yet. I am in the process of a cam and heads swap. After all of that, i am going straight down to the track and see what my lil baby can do. Sorry I don't have any times though Do you have similar mods or something?
Old Mar 17, 2003 | 12:49 AM
97CamaroZ28R's Avatar
I would suggest a exhaust cut-out. It is cheap ($50-$60 installed)and good for a good HP gain(5-8HP). It might be too loud for you with-out cats, but you could always cap it.
I have a cut-out, but it is too loud with LT's and cats! I love the way it sounds, but I am afraid I will get a ticket. That is why I will soon install a dmh electric cut-out so I can turn it on and off when I want.
Old Mar 17, 2003 | 09:23 AM
Dupont24's Avatar
No smokin...just saw your mods and was curious as to how they ran on the track. I plan on doing alot of what you have done and are doing..that's all
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
