please help! how do i know if thermostat is broken?
Old Mar 15, 2003 | 04:10 PM
1.8ttolt1's Avatar
trying to get heater to work, flushed heater core, didn't fix it, know i took out thermostat, but i don't know what to look for.
used this link as reference but i don't know what to compare to. http://csce.uark.edu/~jgbertr/rb/tstat.jpg
Old Mar 15, 2003 | 04:37 PM
chesee48's Avatar
If your qusetioning the tstat and how it might not be working, i say buy a new one. They are CHEAP AS HELL. It couldnt hurt and this way you'll know its not messed up or will get messed up as quickly cause its new.
Old Mar 15, 2003 | 04:52 PM
J96Z's Avatar
Well I say just change it since it is out. My car was running hot and I changed it as a starting point to see if that was the problem. Sure enough it was. It was still opening and closing but at the wrong temp. Just make sure you get the right one because a standard sbc thermostat will not work. I think they are under 10 bucks for a new one.
Old Mar 15, 2003 | 05:13 PM
Joe K. 96 Zeee!!'s Avatar
I say test it....here's why:
You need to know what the problem is and testing it is easy.
Put the thermostat in a pot of water and bring it to a boil. Use a cooking thermostat to see what temp the auto thermostat opens.
Simple. Then you'll know for sure!
Jeff1904
Jun 5, 2016 05:00 PM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
maverickmk
Sep 1, 2015 09:17 PM
MikeWhitener
Aug 2, 2015 06:17 PM
