Car won't start
Old Mar 15, 2003 | 03:03 PM
chasc's Avatar
Unhappy Car won't start
Help - my '93 z28 (totally stock) has just decided it doesn't want to start. It has been starting first turn, even on cold mornings or after standing but suddenly doesn't want to fire. I spins over OK but will not fire. The opti and other ignition componenets were replaced about 3000 miles ago and the car hasn't been run in the wet very much.
There is a slight smell of gas under the hood after cranking it over but does this mean that there is enough reaching the engine. It is obviously either gas or ignition but what would be you're best guesses. It cam on very suddenly, unlike the problems I had when the opti was replaced. Please help a poor limey!
Thanks guys
Old Mar 15, 2003 | 03:35 PM
joeSS97's Avatar
If you are smelling gas it must not be firing.Pull a plug and ground it .Have someone crank the starter to check for spark.If no spark,either the coil or ignition module are suspect.
Old Mar 15, 2003 | 04:18 PM
MEAN LT1's Avatar
Its most likely the coil if anything.
Old Mar 15, 2003 | 04:32 PM
96ltz's Avatar
Pull the injector fuse and the coil wire from the opti. Hold the wire about 1/4" or so from a good ground (engine block, bracket, ect.) and have someone crank the car to check for spark.
Old Mar 15, 2003 | 05:23 PM
ponykiller z28's Avatar
Are you sure you don't have a killer after you?
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
