easier to cut cag wires instead of pulling them??
Old Mar 15, 2003 | 01:19 PM
1.8ttolt1's Avatar
i am gonna do some work on the 94 Z M6. just read a how to !cags. wouldn't it be easier to cut the two wires instead of pulling and taping them?
Old Mar 15, 2003 | 01:28 PM
Crawl under the car, grab the harness connector and unplug it. Tape the ends to keep water out. Why would you want to damage the wires, rather than simply unplugging it?
FYI, unplugging or cutting the wires on a 94 or 95 will not light the SES light, but the PCM will store code DTC 84. You can only eliminate the code if you add the 2.2Kohm resistor in the harness connector, or accross the correct pins at the PCM.
TRANNY CONNECTIONS
Old Mar 15, 2003 | 03:10 PM
madhatter's Avatar
use this
http://www.bfranker.badz28.com/96SS/skipshift.htm
takes 5 minutes, no cutting. just unplug from the PCM and tape off. worked on mine, no SES light but a code is permanetly stored in the PCM.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 12, 2014 10:51 PM
Jul 4, 2005 05:00 PM
Highlander
Aug 9, 2002 02:30 AM
